Problem sizing a single label
I’m trying to create a user defined label, to print one at a time. I want it 1 inch high and 2.621 inches wide.
I’ve started a new copy of Writer.
I’ve gone to File>New>Label and selected “User”.
I’ve entered the correct Horizontal and Vertical Pitches, the Left and Top Margins, the number of columns and rows on the page, and the page width and height. But when I try to enter the height and width of the label it won’t let me.
Width can not be greater than Horizontal Pitch. The same with Height and Vertical Pitch.
Can you post the other values you are intending to use.
