With libreoffice-5.2.5.1 (built with cups support enabled) and cups-2.2.2, I cannot open a particular spreadsheet. The same spreadsheet can be opened successfully if I replace cups-2.2.2 with a cups-2.2.1
The only thing “interesting” about the particular spreadsheet is that it has a user-defined print-area as well as manuallyinserted page breaks. Other spreadsheets without these attributes can be opened successfully.
I don’t know if this is a problem with cups, or with libreoffice. (But Isuspect the latter.)
This is on a NetBSD-7.99.53 release on amd64 platform, and both cups and libreoffice are built from sources using the NetBSD pkgsrc system.
