My system is as follows:
Distributor ID: Ubuntu
Description: Ubuntu 23.10
Release: 23.10
Codename: mantic
LibreOffice LibreOffice 7.6.4.1 60(Build:1)
geany geany 1.38 (built on 2021-10-14 with GTK 3.24.30, GLib 2.68.4)
Python Python 3.11.6
I recently updated to LO7.6.4.1 and now I am getting this message when I run certain python scripts.
Connector : couldn’t connect to socket (Connection refused) at /build/libreoffice/parts/libreoffice/build/io/source/connector/connector.cxx:118
The way to cure this under the last version of LO was by running this script.
soffice --accept="socket,host=localhost,port=2002;urp;
but that does not seem to work any more.
Now when I run it I get this error:
Warning: failed to launch javaldx - java may not function correctly
yodap@yodap-NUC11:~$ java -version
openjdk version “21.0.1” 2023-10-17
OpenJDK Runtime Environment (build 21.0.1+12-Ubuntu-223.10)
OpenJDK 64-Bit Server VM (build 21.0.1+12-Ubuntu-223.10, mixed mode, sharing)
What am I missing?
)…the script was set up to run outside of LO…and I was using it to run inside LO. The problem code was:
