I have been following this guide GitHub - smehrbrodt/libreoffice-starter-extension: LibreOffice Starter Extension. I use :
Windows10
Libreoffice 5.2
Libreoffice SDK 5.3
java jdr8u121.
I do all steps but when i load the extension on Libreoffice appears this mesage: Could not create Java implementation loader.
Can you help me?
Perché in inglese? Siamo nella sezione in italiano.
Mi sono pure impegnato con il mio inglese maccheronico
comunque sono appena riuscito a risolvere se qualcuno avesse lo stesso problema:
anche se libreoffice, eclipse e libreoffice sdk sono in 64bit le estensioni di libreoffice accettano solo le jdk in 32 bit, ecco il perchè dell’errore.
Please make sure you have selected a JRE with the same bitness as LibreOffice. So 32bit JRE for 32bit LibreOffice, or 64bit JRE for 64bit LibreOffice.
You can choose which JRE LibreOffice uses in Tools->Options->Advanced.
Newer LibreOffice versions (I think since 5.3) should automatically select a matching JRE.
