Hello, I have created the following graph and would like to have the years at the bottom of the graph. Would you tell me how to do it? I just can’t find it. Thanks in advance
Vielen Dank. Du hast mir viel Zeit gespart.
For better visualisation I would combine @anon73440385 and my solution:
Right click -> Format Axis -> Tab: Positioning -> Option: Place labels -> Dropdown: Outside startDialog
Result
Hope that helps.
