I really hope someone can assure me, a Newbie, while I try to learn LibreOffice BASE, version 7.4.3.2.
I have been unable to import my databases from Microsoft Access, so I had no choice but to begin creating my tables from scratch.
I have now discovered, however, an issue that is very concerning to me (but perhaps I am just doing it wrong):
After I saved the first table, I tried to go back and change the Field Type from CLOB to Text VarChar. But it wouldnât let me! So I had to DELETE THE FIELD completely and enter it again at the very bottom row of the table design.
This is really starting to worry me.
Because I am a Newbie, I may accidentally choose the wrong field type or length while designing my tables, etc. Then later on, after my tables are populated with data, will that mean that I will LOSE DATA if I have to delete a field name and re-enter it at the bottom?
