Definition of a “word” depends on the locale.
With locale “deutsch (Deutschland)”, numbers are written with a comma and a sequence like <digits>,<digits> is considered a word and selected as a whole by double-click. On the contrary, a number with a dot doesn’t comply with German grammar and will be decomposed into three parts integer, dot, fractional part. Double-click will only select a single part.
If this does not work, check various configurations:
- your OS locale (you didn’t mention it nor the OS name): it may be set to de_CH (Switzerland) where the decimal separator is a point
- in LO
Tools
>Options
, Language Settings
>Languages
where:
Locale setting may be forced to a different locale than in OS
Decimal separator key may differ from locale settings
Default Languages for Documents may also be forced
If you frequently write in a language different from the default for the OS, you can change LO configuration (but it will be changed for all future documents) or change the language in paragraph style Default Paragraph Style, Font
tab (this change will cascade to all other styles).
You can also prepare a custom template for each of your languages and create new documents from this template.
