When I press F1 or select Help I get this message:
“Enable JavaScript in the browser to display LibreOffice Help pages.”
How do I enable JavaScript on my computer?
Windows 10 (1415)
LO 7.2
Windows 10 (1415)
LO 7.2
Remove or edit the settings in the script blocker on your browser, e.g. NoScript
See this site for answer
NB if NoScript removed but Javascript still doesn’t run on Firefox then you can turn Javascript on in Firefox about :config as in this site instructions (but toggle javascript:enabled to True instead)
While NoScript was active, I opened about:config and typed “javascript” into the search box. A whole lot of java-related stuff appeared. Most were already marked “True”, but some were marked “False”. The term "javascript:enabled was already marked “True”.
What other items would you suggest that I mark “True” - surely not all of them?
I don’t use NoScript but FAQ on their site says you can “you have to Allow file://, either from the NoScript menu or the NoScript Options Dialog.”
Otherwise check out their forum
Hi @EarnestAl
I’m using NoScript 11.2.11 and cannot find anything about JavaScript. What version are you using?
This seems rather off topic for a site about LibreOffice.
