I tried to switch from OpenOffice Portable to LibreOffice Portable since its release.
Since the default Decimal separator for Peru is wrong (the right one is the dot not comma), I try use the following language settings :
User interface : Spanish (Spain)
Locale setting : Spanish (Ecuador)
Decimal separator key : Same as locale setting
Default currency : PEN S/ Spanish Peru
These settings stick only if I start LibO as administrator every time. If I change the settings without starting LibO (and restarting it also) as administrator, the User interface will stay at English (USA).
I would like to be able not to start LibO as administrator every time and have the language settings stick.
Thank you very much for your help.
Erich
