Hi everybody,
I have two problems.
In the sheet circo I use lookup at each row of the column E to look for the number of the column A which is in in the sheet legi somewhere in the column D and which corresponds at this row to a number of the column F (of this page). There are way too much number 3 in the column E. The column F doesn’t have so much number 3.
For instance for the first row of the sheet circo, there is the number 59416 in the column A. In the sheet legi 59416 is in the column D and shows 15 in the column F. But lookup shows 3.
I don’t understand this. Please could I get some help ?
When there is a text in the column A, lookup “dies” and I have no result.
I would be glad to learn how to solve this problem.
The file is here:
