I am using the formula "=MATCH(E2&D2,‘Mailman’‘s Route’.A$2:A$500&‘Mailman’‘s Route’.B$2:B$500,0)”
Where Mailmans route is a list of Street Names in Colum A and Street Numbers in Colum B
If I cut and paste the Street Name into Colum A from the data set that I wish to find matches in then everything works perfectly. If I type the street names into Colum A then some streets will do a match and others not
In the above example, both Glastonbury Drive and Quantock Place are in the data set only Glastonbury gets matched
with Quantock not being matched. I have cut and paste Quantock for Quantock 2 below and only then it will match (see below)
Quantock 2 will match but Quantock 4 etc will not
This has me stumped can a nice person help
Thanks Stuart
