I made on a Windows 10 computer a database connection with Base to the MySQL server at my provider. I try to do the exactly the same on a Linux Xubuntu 18.04 computer and I got this Error message:
Errorcode: 2026
SSL connection error: unknown error number
I chosen the following steps to make the connection (translated from the Dutch version, hopefully you understand the items):
- Step 1: Select Database → Connect wit an existing database → MySQL
- Step 2: Set MySQL-connection → Connect directly
- Step 3: Settings of the server for MySQL → fill in of database name → fill in of servername and port
- Step 4: User verification → fill in of user name, etc.
As mentioned I did in Windows 10 version exactly the same and it worked.
Who has any solution?
Thanks for reaction!
What can this say?
