Good evening,
I am not familiar with coding in Basic. I have trouble with running a macro recorded in LibreOffice calc 24, in Linux Mnjaro desktop environment.
I have a data enry form in Calc. I want the entered data to be pased in the same file, but in another sheet. I have created a push button and assigned macro to it. However if i click the button, macro does not run. If I click on Tools: Macro: and try to run macro, it does not run. However if I click Tools: Edit macro: and then click run (green button), it works.
I must be missing something simple and your help is much appreciated. I am pasting the macro below.
REM ***** BASIC *****
Sub Main
Sub Macro1
sub hunar
rem define variables
dim document as object
dim dispatcher as object
rem get access to the document
document = ThisComponent.CurrentController.Frame
dim args1(0) as new com.sun.star.beans.PropertyValue
args1(0).Name = "ToPoint"
args1(0).Value = "$T$4"
dispatcher.executeDispatch(document, ".uno:GoToCell", "", 0, args1())
dim args2(0) as new com.sun.star.beans.PropertyValue
args2(0).Name = "ToPoint"
args2(0).Value = "$T$4:$T$48"
dispatcher.executeDispatch(document, ".uno:GoToCell", "", 0, args2())
dispatcher.executeDispatch(document, ".uno:Copy", "", 0, Array())
dim args4(0) as new com.sun.star.beans.PropertyValue
args4(0).Name = "Nr"
args4(0).Value = 7
dispatcher.executeDispatch(document, ".uno:JumpToTable", "", 0, args4())
dim args5(0) as new com.sun.star.beans.PropertyValue
args5(0).Name = "ToPoint"
args5(0).Value = "$A$1"
dispatcher.executeDispatch(document, ".uno:GoToCell", "", 0, args5())
dim args6(5) as new com.sun.star.beans.PropertyValue
args6(0).Name = "Flags"
args6(0).Value = "SV"
args6(1).Name = "FormulaCommand"
args6(1).Value = 0
args6(2).Name = "SkipEmptyCells"
args6(2).Value = false
args6(3).Name = "Transpose"
args6(3).Value = true
args6(4).Name = "AsLink"
args6(4).Value = false
args6(5).Name = "MoveMode"
args6(5).Value = 0
dispatcher.executeDispatch(document, ".uno:InsertContents", "", 0, args6())
dim args8(0) as new com.sun.star.beans.PropertyValue
args8(0).Name = "Nr"
args8(0).Value = 6
dispatcher.executeDispatch(document, ".uno:JumpToTable", "", 0, args8())
dim args9(0) as new com.sun.star.beans.PropertyValue
args9(0).Name = "ToPoint"
args9(0).Value = "$A$2"
dispatcher.executeDispatch(document, ".uno:GoToCell", "", 0, args9())
dim args10(5) as new com.sun.star.beans.PropertyValue
args10(0).Name = "Flags"
args10(0).Value = "SV"
args10(1).Name = "FormulaCommand"
args10(1).Value = 0
args10(2).Name = "SkipEmptyCells"
args10(2).Value = false
args10(3).Name = "Transpose"
args10(3).Value = false
args10(4).Name = "AsLink"
args10(4).Value = false
args10(5).Name = "MoveMode"
args10(5).Value = 0
dispatcher.executeDispatch(document, ".uno:InsertContents", "", 0, args10())
dim args11(0) as new com.sun.star.beans.PropertyValue
args11(0).Name = "Nr"
args11(0).Value = 5
dispatcher.executeDispatch(document, ".uno:JumpToTable", "", 0, args11())
end sub
