Hi,
When I have to sum some numbers in cells i got this message LibreOffice - 4.3 fatal error “Text forwarder is invalid, object is defunc”
my libreoffice version is
Version: 4.3.1.2
Build ID: 430m0(Build:2
Hi,
Version: 4.3.1.2
Which OS are you using? Which steps are you doing before the error message appears?
Ubuntu 12.04.5 LTS
first i type the numbers in each cell and then I click the icon “SUM” the cells are automatically selected after I click Accept then appears the error “Text forwarder is invalid, object is defunct”
Same problem here, same version and platform.
Workaround is to avoid the button and type the sum manually.
