LibreOffice 4.4.0.3, en_uk, Writer on Windows 7, en_uk
I would like to convert MS Word .doc documents containing embedded draws (containing shapes created directly in MS Word) to .odt
In the converted document, the embedded draws look different from the original and, most of all, it does not seem to be editable (I mean I cannot select and edit any single shape), i.e. each draw seems to have been converted to a bitmap image.
I tried the conversions:
- opening the .doc from LibreOffice and saving as .odt
- opening the .doc from Word 2010 and saving as .odt
- opening the .doc from Word 2010, saving as .docx, reopening the .docx and saving as .odt
Could you please suggest a solution so that the original draws remain embedded and editable, perhaps through LibreOffice Drawing?
Thanks in advance!
