problems on LibreOffice Base 6.1.1.2 (x64)
I have a database I made on Base and it use to work well with all the labels I created for my custom reports. Unfortunately since I updated to the newest version, my information from the labels appears to be deleted and labeled as “Label” for each label I made. I think it might be a bug because I tried this on an old computer with an older LibreOffice and it worked fine until I made the newest update and it did the same thing.
Is this intentional or is this a bug that is currently being investigated?
Just another bug in Base - Bug #119067
I am havin the same problem on MacOS. Is there a place where I can access any work on fixing it on MacOS?
@jorengo This bug has now been fixed. LO v 6.1.3 no longer has the problem.
I am on LO 6.1.2.1 for MacOS. Can you please indicate how to download the fix for MacOs? I already tried by selecting update. thanks
@jorengo You need to install the latest release → LibreOffice 6.1.3
