I have used version LibreOffice 7.1.3.2 with Windows 10, successfully printing with my Ricoh Aficio SP C232SF laser MFP. I have now switched to an M1 MacBook Pro, using Monterey 12.0.1, with version LibreOffice 7.2 and later with 7.1.7.2, and after sending a document to print from Writer the printer receives it and gets stuck in a “processing” loop which can only be halted by switching the printer off. The same thing happens with Calc documents. Can someone help please? Thank you.
Make sure you have the Printer selected in the print dialogue and not the Fax, this has happened to me in the past.
If still not working, can you print a pdf from Adobe Reader?
