Hello, fellows. Thanks for the opportunity to ask in this forum.
I have a Writer document into which I need to insert several SVG images created with Inkscape.
When I insert a SVG image it renders perfectly on screen. I can zoom in and out and all the vector properties of the image are fully preserved. Furthermore, when I export the document as PDF, the resulting image in the generated PDF file also looks fantastic. So far, so perfect!
The problem is when I save the Writer document (containing the SVG image), close it and reopen it - the original SVG image is apparently rendered, and very, very poorly!
I have spent quite some time investigating if Writer converts a SVG image to some other format when a document is saved, or if the problem resides in the document opening process. No success…
I am using LibreOffice 7.0.3.1. Images are created with Inkscape 1.0.1 and saved as Inkscape SVG files. I have already tried saving the original SVG images as ‘Plain SVG’, EPS etc. with no success.
Any help is welcome! Thank you all in advance.
