Problems with macros: Unable to identify problem
Hello again community,
Hope everithing fine.
We have a problem to solve and don’t know how.
We would like to implement a macro, but it doesn’t work nothing.
Our PC says literaly screw you and tell us to take another way.
I don’t know what to do.
May you help us?
Thanks in advance.
See ya!
maybe… by exposing the problem, someone can help… we are very bad at guessing
If this is really the precise message by your PC, I’d interested in the OS - obviously not made by Apple, a Mac would tell this in polite words.
As I have learned long time ago it is my fault if computer said SN-ERROR I usually accept my fate and will not discuss your PCs judgement.
And maybe there really is a solution without the need to
My problem isn’t that quick to solve, maybe. Idk
You know, there is that fabulous new technology called “artificial intelligence”.
Tell Eliza about your problem.
You’re right, but… also with them did not find any solution…
You know, I remember a very old story.
One company used an in-house developed database based on Access.
The programmer, the developer of this database, stayed late on March 31 (he always stayed the longest) and prepared an April Fool’s joke. After starting the program, after 10 seconds of work, a pop-up window appeared on the screen, stylized as a system error with the text “The program performed an impossible operation, invalid user, replace and strike any key …” (or something like that).
When the programmer came to the office for dinner, the accounting department had already called MS technical support three times. For the first time they were listened to and advised to restart the computer. Of course, it didn’t help. During the second appeal, technical support said that the Board of Directors of the Corporation had gathered and was solving this problem. An hour later, during the third call, they were told that the cause of the error had been found and would be fixed in the next version…
Why did I remember this story? Couldn’t it be that you were the victim of a cruel prank on Sunday night? Just in case - advice: lie down, close your eyes, imagine Hopfenperle or Schützengarten… and on Monday morning the problem will disappear by itself … or not disappear …
@JohnSUN : You made my day!
