Problems with Writer
Salute!
Guys tell me I have a problem with the office on Windows 7, when installing, a warning 1946 appears, everything works for me except Writer. Version Version: 7.1.1.2 (x86) / LibreOffice Community
Build ID: fe0b08f4af1bacafe4c7ecc87ce55bb426164676
CPU threads: 2; OS: Windows 6.1 Service Pack 1 Build 7601; UI render: Skia / Raster; VCL: win
Locale: ru-RU (ru_RU); UI: ru-RU
(inline display fixed by ajlittoz)
tdf#84456 is likely unrelated to the Writer failure - and you didn’t explain what “except Writer” means - some error message? crash? unexpected results?
Everything else opens without problems except for Writer, there are no problems with presentation and tables. I do not know how to say this, writes that it cannot open and goes from sending a report and goes into safe mode and again everything in a circle. I indicated everything in the screenshots.
Literally writes:
'An error occurred in LibreOffice that you were working on will be saved. When you start LibreOffice, your files will be restored automatically. ’ And so in a circle. And this only happens with Writer.
