A conundrum for the Gurus.
If I open LoCALC and simply set the page format to A4 with all the default margins CALC then produces a marquee defining the print area.
I fi focus the first cell in row 1 outside the marquee and then select all cells to the right with CTRL+SHFT+RIGHT and then “HIDE” the columns using the context menu, the process is instantaneous.
If I then focus the first cell in column A outside the marquee and select all the cells to the bottom and “HIDE” the rows using the context menu, the process takes 4 minutes plus.
If I reverse the processes using the toolbar button, the inference is that I’m undoing row height/column width changes and the process is also instantaneous for both UNDOs.
However;
If I select the columns and >Data>Group and Outline>Group them, then use the control button to hide them, the process is still instantaneous.
If I select the rows and >Data>Group and Outline>Group them then use the control button to hide them, the process is AGAIN instantaneous.
The UNDO button now infers that I’m undoing “Hide details”.
My questions:
Why is “Hide” claiming to be adjusting the width/height metrics of the column or row, whereas “Group” is claiming to be adjusting the “Hide” characteristics of the related columns/rows?
Why is one process far more efficient when operating on columns than when operating on rows?
Wouldn’t it be a little more productive to utilise the same procedures for both operations?
Does any of the above constitute a bug report?
