Hello all,
I’ve posted a first draw of this proposal here on this forum as a reply, but as the original post dates from some years back, I’m afraid the proposal might go unnoticed. Hence this new question/proposal.
I assume that most of the LO Base developpers have been confronted with the problem of “need some little changes between versions”, like a background color here, a label text there, a database name in any number of places, the database user, and so on …
Well, at least I did when I decided to have a development version and a production version of an application I’m building (my first one in LO Base). After alot of googling around I found no working solution for this issue, so I was stuck with making the same manual changes over and over again with each new ‘production version’ …
Then I read somewhere (on this forum, I think) that an odb file is basically an archive (kinda zip) file, so I unpacked one and started nosing around in the various files within.
I also have some Perl knowledge, so I started tinkering with some code to explore an odb file, and lo and behold, I now have a script that reads an odb file, goes over all (xml) files inside, looks for certain strings, replaces them with other strings and writes out a modified version of the odb file (under a different name).
Of course I have to be carefull of what strings I replace in order not to end up with a ‘broken’ output odb file, but now I can make a ‘production version’ of my LO Base application (157 changes !) in +/- 0.11 seconds instead of spending half an hour or so (and hoping I don’t miss something) making the manual changes.
Here is an anonymized output of the script:
* Patch ODB File v3.10 *
Parameter file : Patch_ODB.parm
- Patch 'DB-Color' : Replace 'ffd7d7' with 'dde8cb'
- Patch 'Database' : Replace 'Xyz_DEV' with 'Xyz_PRD'
- Patch 'ReportLabel' : Replace '\* T E S T \*' with ' '
- Patch 'User' : Replace 'userdev' with 'userprd'
Parameters loaded OK.
PROCESS ODB FILE
- Input file : 'Abc_TST.odb' read
Member : content.xml
- 'Database' patched : 86
- 'User' patched : 1
Member : forms/Obj11/content.xml (_Menu)
- 'DB-Color' patched : 1
- 'Database' patched : 2
< --- cut --- >
Member : reports/Obj71/content.xml (Rpt_something)
- 'ReportLabel' patched : 1
< --- cut --- >
Member : settings.xml
- 'Database' patched : 60
- Output file 'Abc_OUT.odb' written.
EXECUTION STATISTICS
- 'Database' patched : 149
- 'ReportLabel' patched : 6
- Total members parsed : 128
- Total members patched : 10
- Total patches applied : 157
- Elapsed time : 0.11 seconds
* Patch ENDED *
This script is now in a state that works for my personal situation, but with a little more effort I can turn it into something that anyone who can edit a parameter (text) file and run a command line script (.cmd or .sh) can use (after checking/installing perl, that is).
I’m willing to put in the effort, but I would like to know :
Is anyone interested in such an odb-patch script ?
(Am I really the first one to come up with something like this ?)
What should be ‘delivered’ and where ?
Only the script file and a sample parameter file ?
Some documentation (readme) ?
A sample odb file to demonstrate the patching ?
Just put everything in a zip file and post on this forum ?
Thanks for your time reading this, and for your feedback.
