How is it this does not work? Function ParseLocation(strSourceText As String) As Variant() according to this, it should.
How in the world is this Argument is not optional?
Private Function ParseLocationText(strSourceText As String)
' Have already stepped through this and 'it works'
End Function
Dim Values(5) As Variant
Values = ParseLocationText(strSourceText)
ParseLocation = Values
End Function
I have tried with and without declaring Values to no avail.
Okay finally got at least some result, a step forward. Returns a Double() or Variant(). But that is only setting the first value in a single Cell. I want to populate a target Cell Range, preferably for the row from which the source test is drawn.
I did start the post out with the intention of leaning into the python side. Possibly looking at the Pythonista to help with that, Iām not sure.
Just from a BASIC perspective, how do I convey a cell range to the Function? Or a Sub, or whatever. And/or return with the same.
This is a step forward, and the Cells appear to be addressed properly by row and column, but the result is still displeasing, the values are not landing properly in the sheet.
Function ParseLocation(ByVal strSourceText As String, oDestRange As Range)
Dim Values() As Variant
Dim oSheet As Object
Dim oCell As Object
oSheet = ThisWorkbook.ActiveSheet
Dim I, Row, Column As Integer
For I = LBound(Values) To UBound(Values)
Row = oDestRange.Row
Column = oDestRange.Column + I
oCell = oSheet.Cells(Row, Column)
oCell.Value = Values(I)
Next I
ParseLocation = ArraySize(Values)
End Function
Note, I am also, FWIW, which appears to have some impact on the Sheet and Cell classes involved:
Option Explicit
Option VBASupport 1
Only the first and either the last value or returned size are populated.
| survey | x | y | z | pitch | yaw | roll | ||
| {X=1 Y=2 Z=|P=4 Y=5 R=6} | 1 | 6 | 6 |
Have verified the parsing is correct should be six values in all.
https://docs.libreoffice.org/sc/html/classScVbaWorksheet.html
https://docs.libreoffice.org/sc/html/classScVbaRange.html
This appears to work, but man getting there, one climb after the next.
Dim Size As Integer
Size = ArraySize(Values)
Dim oCell As Object
Dim oStartCell As Object
Dim oEndCell As Object
Dim oRange As Object
Dim Row As Integer
Dim StartColumn As Integer
Dim EndColumn As Integer
StartColumn = oDestRange.Column
EndColumn = StartColumn + Size - 1
oStartCell = oSheet.Cells(Row, StartColumn)
oEndCell = oSheet.Cells(Row, EndColumn)
oRange = oSheet.Range(oStartCell, oEndCell)
oRange.Value = Values
Again, somewhat if not entirely dependent upon: Option VBASupport 1.
Here instead of iterating I work back to the ranges, cells, and set the values to the array result. And voila, the range lands in the cells as expected.
And with that, still there may be some room for Pythonista analytics forward from this breakthrough.
The StarBasic+API of the LibreOffice is not VBA.
(VBA: Visual Basic for Applications. The VBA is a Microsoft product.)
(API: Application Programming Interface)
Never will be 100% compatibility between the VBA and the StarBasic+API.
Try to avoid to use the āOption VBASupport 1ā in the LibreOffice.
Generic programming rule:
The āFunctionsā has one or more RETURN values. They are named āReturnā values because they will return to the place (Cell or Cellrange) where the Function was called from. And not to other places. The VBA breaks this rule.
ā¦
Then I have to ask the question: why entertain it as an choice, a āfeatureā, and it isnāt fully supported? i.e. declaring Function As Tytpe.
Notwithstanding VBA breaking the Function result to Cell or CellRange, aspect.
Still, good to know.
What are the equivalent docs for the Worksheet, Cell, CellRange and so forth? Assuming possibly also needing some flavor of the ScriptForge services.
Best, and thanks so much.
Just think a bit yourselfā¦
Shall they remove everything, wich does not function āfullyā?
- reading xls. Format was never documented as standard.
- reading xlsx. There is some standard, but MS usually stores in an āextendedā format
- reading csv, as there is no standard.
- macro-recorder will not catch everything, so lets remove it
- as suggested by you: forget about VBA-macros, if not all MS-macros are running
- pdf/X not supported, so remove pdf-export
ā¦
Or we can leave all this in, so people can test, if it is useful for them.
For best compatibility with MS-Office I recommend MS-Office ( Even this fails sometimes ⦠)
Question, when I return the Variant(), only the first value is placed in the given CellRange. How do I actually have ALL the values land in the range?
After dropping VBASupport, then I am also back to, parameters as values, not the spreadsheet objects, ranges and so forth.
How do I ensure passing the cell address, range addresses, etc?
In the VBASupport approach, this was āworkingā:
Dim Row As Integer
For that matter, I might even have be able to just set the Values on the argument, oDestRange As Range.
What is the non VBASupport equivalent of that? Or at least some doc references, please, that would be helpful.
What is the non
VBASupportequivalent of that? Or at least some doc references, please, that would be helpful.
This is much of my consternation. The docs are either INACURATE AF, or need updating.
One key area, for instance, are INDEXING. Providing SHEET() for instance from the worksheet perspective, CORRECTLY yields 1 in this case. However, ThisComponent.Sheets.getByIndex(1) throws IndexOutOfRangeException.
Yes or no, INDEXING SHOULD BE ONE BASED, NOT ZERO!!!
It should really not be this difficult to simply write some macros, Sub, Function, whatever. Yes, it is effort to write any sort of code, but with this every single word, line of code, is earned to the Nth degree. Really is exhausting to work with for no good reason, when docs are unreliable, runtime behavior is inconsistent, or outright incorrect, according to known BASIC principles, let alone āVBAā or Calc appliances.
Another take away, bearing in mind LO is doing BASIC things on a Java based infrastructure, which is, last time I checked, zero based indexing. But still⦠When SHEET() is correctly reporting 1 for the first sheet⦠That is inconsistent with the native LO BASIC infrastructure.
To be fair, I know the LO team are not the purveyors of the DF wiki site, but still; they must be basing the examples on some ostensibly well known source of truth.
https://wiki.documentfoundation.org/Macros/Basic/Calc/Sheets
Have verified, I have an object in oCellRange from the appropriate rows and columns. Also arrValues are correctly there.
oCellRange = oSheet.getCellRangeByPosition(iStartCol, iRow, iStartCol + iSize - 1, iRow)
oCellRange.setDataArray(arrValues)
From the sheet formula =PARSELOCATION(B3,C3:H3, SHEET(), COLUMN(C3), ROW(C3)).
Error: Object variable not set. This is a lie. IT IS SET. I verified it.
Again, Iām just working from the docs.
https://docs.libreoffice.org/sc/html/classScTableSheetObj.html
https://docs.libreoffice.org/sc/html/classScCellRangeObj.html
So if there is some object or other not being set, itās not my code not setting it.
surveys.ods (20.7 KB)
Posted the ODS after all⦠Where it stands now, Object variable not set.
Iāve checked in the watch, it is set, AFAIK.
I suppose not surprisingly, indexing is also 0-adjusted not 1-based getting the cell range, as well.
If I have to iterate the cells themselves relative to the range, assuming thatās according to getCellByPosition(...) with 0-indexing relative to the range instance, yes?
Without inspecting code, best guess, the internal implementation is probably broken, guessing around perhaps the same assumptions, whether 0-based or 1-based indexing, and in which contexts that should be the case. C C++ obviously is 0 based, as is Java. However spreadsheets, BASIC, are often 1-based by default, and should be respected as such.
Was forced to resort to the following workaround which seems to have worked.
oCellRange = oSheet.getCellRangeByPosition(iStartCol - 1, iRow - 1, iStartCol + iSize - 2, iRow - 1)
' Broken, fails internally: `Object variable not set`
' The workaround is to iterate the Cells from the range itself
Dim I As Integer
Dim oCell As Object
For I = 0 to iSize - 1
' And which, yes, as semi-intuitively expected, both relatively indexed, and 0-based
oCell = oCellRange.getCellByPosition(I, 0)
oCell.setValue(arrValues(I))
Next I
Cell positions are indexed relative to the range, and are 0-based, which I think is inconsistent with the spreadsheet, never mind BASIC, expectation, that indexing should be 1-based. Always has been since at least Microsoft Excel days and before that. But please do not mistake that as any defense of Microsoft, I am not (defending). Iām just saying broader industry wide, spreadsheets are generally 1-based indexed by their intrinsic nature, whatever the programming API infrastructure is around it.
Approaching conclusion of this issue, I think. FWIW, my two cents.
Should also mention, I am not the first to have encountered this issue around setDataArray, etc. Has been reported in at least this forum since at least 2021.
And I posted my modified sample file again:
Parse_Zizi64_b.ods (19.2 KB)
The function written in Basic only, no Python.
The Function was called conventionally, the function will modify ONLY the cell range where it was called from.
The function has an Array output.
The function ParseLocation is called 10 times in the rows (and once the function CreateHeader)
And I will reiterate @Zizi64, first much appreciate as a starting point; second, insightful as a good starting point.
The Function will modify ONLY the cell range where it was called from.
Only the first element in the array lands in the source cell where the function was called, i.e. DOES NOT WORK!
Anyway, I adapted from there and manually place the array values in the desired source range. Values should land in a specified target row and member columns; I adapted toward that goal.
Certainly if there is a better more flexible way of doing it, through BASIC, employing py adapted solutions, Iām open to hearing it.
Notwithstanding the indexing issue, and apparent bugs in the BASIC object class API implementations, and so on.
Which result, for instance, is not displeasing. Will have to see how Pythonista is at working with those ranges to discover key analytics and so forth.
And what is required to connect the dots, =PARSELOCATION(B3, SHEET(), COLUMN(C3), ROW(C3)). I tried delivering the array range starting at the cell, but the only value that landed there was the position X value, nothing else. Rather I simply return the count of values parsed, more or less, for now.
