@markamathews,
we do not know which database you use.
libreoffice comes with 2 databases hsqldb 1.0.x embedded and firebird 3.x embedded neither of which contain the ROUNDUP function.
Wanderer suggested a solution 12 days ago, did you try it? what was the result?
UNION is the way to go.
- open your db.
- hit Queries icon.
- hit Create Query in SQL View.
- paste the sql code.
- select direct mode (see pic).
- hit F5 to execute.
caveats:
the total amount needs to be the final record shown therefore I have added the field “Level”.
UNION requires direct mode i.e. menu:>Edit>Run SQL command directly (see image)
![Direct_Mode](https://ask.libreoffice.org/uploads/asklibo/original/3X/7/d/7dd37c032217eda14590a0e9bf00a3de75088ed8.png)
EDIT 2024-04-17
just remembered that when using embedded hsqldb ORDER BY clause can only be used once and must be last line of code. sql is now updated.
select
"Item",
"Amount"
from
select
1 "Level",
"Item",
sum("Amount") as "Amount"
from
"Counting"
where
"Date" = '2024-02-26'
group by
"Level",
"Item"
union all
select
2,
'**Total**',
sum("Amount")
from
"Counting"
where
) a
order by "Level", "Item"
