I have opened a Microsofet Excel file in Calc which has been set not to display zeros in fields with zero values. However when I print the zeros are shown. How do I prevent this from happening?
to not print zero values, you need to unset:
Format -> Page... -> Tab: Sheet -> Section: Print -> Option: [ ] Zero values
Hope that helps.
Many thanks. I just could not find the setting.
If the answer fixed your problem, please consider to click the check mark () next to the answer. Thanks in advance …
