I created a user library. I created a class module in it.
When a class module is changed, its behavior does not change, as if it were compiled once.
LoadLibrary doesn’t help
Thank you Dyakuyu
Please, show your code. I can’t reproduce your problem in my system.
Version: 7.6.4.1 (X86_64) / LibreOffice Community
Build ID: 60(Build:1)
CPU threads: 16; OS: Linux 6.6; UI render: default; VCL: gtk3
Locale: es-MX (en_US.UTF-8); UI: en-US
7.6.4-1
module “dataRecord” in user library “data”
Option Explicit
Option Compatible
Option ClassModule
private const delimField="|", delim="="
property get SomeProp() as variant
SomeProp=322223
end property
Public Function Field(byref sData as string,sKey as string) as Variant
dim sDataPair as string
for each sDataPair in Split(sData,delimField)
if UCase(Trim( split(sDataPair,delim,2)(0) )) = UCase(sKey) then
on local error resume next
Field=split(sDataPair,delim,2)(1)
on local error goto 0
exit function
EndIf
next
End Function
in other (inside document) module:
Globalscope.BasicLibraries.loadLibrary("data")
' dataRecord is visible as object without props and public methods
const sample="ID=1|value=Some value|alter=Some other"
dim r
r=dataRecord.Field(sample, "ID") ' ERROR, property or method not found
In your example, an instance of the class is not created.
Add a regular module to the data library:
Function New_dataRecord()
New_dataRecord=New DataRecord
End Function
Now call from another library:
Sub Test
Dim dRecord, r
dRecord=New_dataRecord()
r=dRecord.Field(sample, "ID") ' no ERROR
they already gave you the solution to the problem.
But how does this happen, for example, in the SF_Array module?
Is there some module/sub in the library with a reserved name?
After LoadLibrary(“ScriptForge”) we can simply use SF_Array.NecessaryFunction() .
I tried to smoke sources from ScriptForge, but Enlightenment did not come
Well, let’s take it in order.
Smoke this again, just pay attention to the details.
For example, start with SF_Utils. As the name suggests, this thing is very close to the root of the entire SF-tree. Yes, this is where we can see the New operator in the form Set _SF_ = New SF_Root
A nuance that explains a lot - there is no Option ClassModule string in this module.
And this is not in the SF_UI module. And in the SF_Array, and in the SF_Exception… In other words, exactly the mechanism that @sokol92 wrote about is used - next to the class modules there are ordinary modules, which actually create objects of the required classes.
This is not Enlightenment yet, this is only the first step towards it.
Take the next step, explain to us (and at the same time to yourself) - why do you need object-oriented programming if you just need to select a key-value pair from a text string? Why doesn’t a regular function do the job easily and quickly?
Option Explicit
Sub testPair
Const sample="ID=1|value=Some value|alter=Some other"
Dim sKey As String
Dim vValue As Variant
For Each sKey In Array("ID", "wrong ID")
vValue = getSingleField(sample, sKey)
If IsEmpty(vValue) Then
MsgBox "No Key '" & sKey &"' in string '" & sample & "'!", MB_ICONSTOP, "Wrong data"
Else
MsgBox "Value for Key='" & sKey &"' is '" & vValue & "'", MB_ICONINFORMATION, "Result"
EndIf
Next sKey
Function getSingleField(sData As String, sKey As String, Optional FieldDelimiter As String, Optional PairDelimiter As String) As Variant
Dim aTemp As Variant, aSTemp As Variant
Dim i As Long
Dim sDataPair As String
Dim sDataKey As String
getSingleField = Empty
If IsMissing(FieldDelimiter) Then FieldDelimiter = "|"
If IsMissing(PairDelimiter) Then PairDelimiter = "="
Rem If the text Key does not appear in the sData line, then there is no point in continuing:
If InStr(sData, sKey) = 0 Then Exit Function
Rem There are different types of errors in data.
Rem For example, there may be no key-value separator
If InStr(sData, PairDelimiter) = 0 Then Exit Function
aTemp = Split(sData,FieldDelimiter)
For i = LBound(aTemp) To UBound(aTemp)
sDataPair = aTemp(i)
If (InStr(sDataPair, sKey) > 0) And (InStr(sDataPair, PairDelimiter) > 0) Then
aSTemp = Split(sDataPair, PairDelimiter, 2)
If UCase(Trim(aSTemp(0))) = UCase(sKey) Then
getSingleField=aSTemp(1)
Exit Function
EndIf
EndIf
Next
End Function
Or do you expect that someone will also parse your code line by line in anticipation of Enlightenment?
