Can we use Excel (LibreOffice Calc Spreadsheet) as a database and fetch values from it using ADODB connection from UFT?
Previously, we did the same with Microsoft excel with the below connection string.
"Provider=Microsoft.ACE.OLEDB.16.0;Data Source=" & strExcelPath & ";Extended Properties=""Excel 12.0 Xml;HDR=Yes;"&IMEX&""";"
My doubt is, we are migrating to the LibreOffice and I need to know if I can use similar way to fetch values from excel using ADODB. I tried similar connection string but I got an error saying “Unrecognized database format”.
"Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & strExcelPath
Is it that LibreOffice excel do not have a feature to be used as a database or am I using the incorrect way to fetch the values?
