Hi
Been trying for 5 hours now.
Lots of tries from things on various places.
I have database.
Table and forms.
on form is a cPoints text box set to integer
Have another text box txt_AddRemove set to integer.
Need to take the value from txt_AddRemove and add it to cPoints with the push of a button.
this is what I got.
REM ***** BASIC *****
Sub Main ( Event as Object )
rem MsgBox "You pressed Me!"
DIM oForm as Object
DIM oField as object
DIM oPointsField as object
DIM oTotalPoints as object
'gets the form
oForm = Event.Source.Model.Parent
oField = oForm.getByName("txt_AddRemove")
' oField.Text = "500"
oPointsField = oForm.getByName("cPoints")
oTotalPoints = oField + oPointsField
oPointsField.Text = oTotalPoints
oPointsField.commit()
first error only in debug
oForm = Event.Source.Model.Parent Argument is not optional.
when running by clicking on button
oTotalPoints = oField + oPointsField incorrect property value
tried to find convert text to int and int to text. cannot find anything.
if I can get this working I am done.
Thanks all
Not sure how to reply to a comment on my post
Can you not convert text to int, then add, then convert to text. Also all boxes are integers. Can I not pull the value off as an integer.
(Slighly edited by @Lupp for better readability.)
