Hello
LibreOffice 7.2.1.2 (same in older versions). English Language GUI. Windows 10.
Standard module for German language is installed and the spelling seems to work (more or less good).
Cells language is German(Germany).
Issue:
In some cells with German text many/most words are underlined red even if they are correctly written.
Right mouse button click into the cell acts strange. Sometimes a popup appear and sometimes not.
Double click into the cell and all red underlines disappear first.
Change the focus to other cell and the red underlines appear again.
Right click on one of the previously red underlined words and if the popup appear (no suggestions), close it again (left click somewhere else).
Then the complete cell still be without any underlines and looks fine!
Until the file is closed (also saved) and reopened again.
Then the words are underlined again ad I can perform the trick again.
It is just ugly!
Could it be because there is no grammar checking for German available?
In “Language Settings” in “Available Language Modules” and “Edit” there is Spelling checked box but there is nothing to check under “Grammar”.
In “Options” “Check grammar as you type” is disabled/unchecked.
https://wiki.documentfoundation.org/Language/Support/German
Lists only an extra tool for German grammar.
I actually do not want to check the German grammar or install additional tool I do not need.
Any idea how to disable this red underlining?
