I need some help with the Reports on Base,
I’m trying to create a reference index that says which documents are related to a person. For example: John is mentioned in documents 3, 7, 8 … Jane is mentioned in documents 2, 5, 9 and so on. I’ve already created these categories and a Query in order to create the report.
I already know how to prevent a value from appearing multiple times if it is repeated (f.e. John, Jane), but I don’t know how to make that each value that is related with that repeated name (document 2, 3, 4) prints continuously in a row, instead of a column, as Base: Reports normally does.
Thank you.
