There is no indication as to where you placed the code you pasted. You notes are meaningless without the files. I have presented to you two working samples with the code. Is your code in the same place? It needs to be in the document and not in My Macros & Dialogs. Chapter 9 of the Base manual does present some information on libraries & locations. Macros are much more involved than just Base. Having trouble with Base is a sure sign you will have much much problems with macros - even the simplest.
The only thing a reload does is to reload the data. The button will not stop it. Forms (actually its data) get reloaded. Sometimes there is refreshing in a control.
