Hopefully a very simple question.
If I have a column of numbers in Calc: D1:D100
and I have some number in A4,
how do I get E1:E100 to each be equal to the cell to its left divided by A4?
I.e. E1 = D1/A4
E2 = D2/A4 … etc
Thank you!
Shimon
I.e. E1 = D1/A4
E2 = D2/A4 … etc
Thank you!
Shimon
Absolute vs. relative reference:
E1 =D1/$A$4
copy E1 down
Thank you so much!!
As a follow-up, any cells in the D range that were empty, are giving me 0 in the E column.
Is there a way to have E also stay empty when there was no number in D?
A cell having a formula can not be empty. However, it can have an empty string, a text with no characters.
=IF(ISNUMBER(D1);D1/$A$4;"")
IF D1 is a number THEN D1/A4 ELSE empty string
Thank you again!
