In Windows 10, when I right-click in a folder and select the menu item “New”, there are options to create several kinds of documents, but not for Writer or Calc However, there is one for an “OpenDocument Drawing”.
After a new install of LibreOffice, the option to create Writer and Calc documents does show up in the right-click New menu. But after a few restarts, next time I look, only the Draw document remains. This cycle has happened several times, over at least a couple years.
I have followed other advice, and set the appropriate registry entry, for example for Writer:
Computer\HKEY_CLASSES_ROOT.odt\LibreOffice.WriterDocument.1\ShellNew
to the appropriate file, which I have created:
C:\Program Files\LibreOffice\share\template\shellnew\soffice.odt
This ability to create a new Writer document exactly in the folder where you need it with a right-click is very handy. Any ideas on why it disappears, and only the Draw document option remains?
