As a writer, I’m constantly creating new documents and saving them to one of several client folders. But sometimes LibreOffice tries to save them in a folder called “218” instead. How can I make that stop?
[Edit - Opaque] removed tags “as” and “218”
Could it be you are using Linux (Ubuntu or one of its derivatives) and a snap version of LibreOffice?
Anyhow: Please provide information from Help -> About LibreOffice and the full path of your folder 218.
Thanks for your response. I downloaded LibreOffice 7.1.3.2 via the Zorin distro of Linux.
The “Save As” path shown is “home/kentraco/snap/LibreOfffice/218”. But under “Home”, there is no “kentraco” folder.
I should point out that this problem occurs intermittently. I see no pattern to it.
Home vs /home (Linux is case sensitive and the full path look like to be: /home/kentraco/snap/LibreOfffice/218).
Hello
set a new path to My Documents in Tools -> Options -> LibreOffice -> Paths which by default is set to $HOME/snap/libreoffice/218 - see the following screenshot from a fresh ZorinOS 15 installation using snap version of LibreOffice.
This causes to select $HOME/snap/libreoffice/218 if you use Save As on a new document.
And now I understand your use of term HOME, which is one of the “facts-hiding” features of GNOME desktop manager, which is why I don’t like it. Open a terminal and use commands echo $HOME,ls -l,pwd and you get what your system really has.
Hope that helps.
I made the edit you suggested, changing the path to the folder I use most often. That seems to have solved the problem.
If the answer works for you, please consider to click the check mark (
) next to the answer. (That’s the way to indicate a correct answer, there is no need to close a question). Thanks in advance …
