I’ve been experiencing issues when using WebP images in LibreOffice Calc. Specifically, when I insert a WebP image into a spreadsheet and save the file, the saving process takes around 3 seconds. However, if I insert the same image in JPG format instead, the saving is instantaneous.
Additionally, I noticed a significant difference in file size. The spreadsheet containing the WebP image is approximately 30 MB, while the one with the JPG version of the same image is around 20 MB.
After examining the saved spreadsheet by converting it to a ZIP archive, I discovered that the WebP image had been converted to a PNG format internally. Given that the original WebP image was only 3.3 MB, I suspect LibreOffice decompresses it during the saving process, which could explain the increased save time and file size.
Here is the resulting files: Proton Drive
Version: 25.2.3.2 (X86_64) / LibreOffice Community
Build ID: 520(Build:2)
CPU threads: 16; OS: Linux 6.14; UI render: default; VCL: kf6 (cairo+wayland)
25.2.3-3
Best regards,
NStar
