Scrolling through fonts in writer and calc crashes the app. Using Windows 7 and LO 3.6.3.2. I think this is a bug just for me though :p. Can’t imagine that being a bug getting through the testing. Might be a font of mine doing some weird stuff. Is there a place where i can deactivate certain fonts used in LO? I have a CAD app that uses its own fonts so i dont want to damage that.
Thanks for your answers. This is how i got it to work for me.
when replacing the bugged font in options-fonts you can eliminate the bug
https://plus.google.com/photos/118180357581642391868/albums/5821817380461869681?authkey=CN_GlcKx_ZK3Hg
Have you try resetting the user profile?
Sometimes solve strange issues.
http://wiki.documentfoundation.org/UserProfile
You might try:
Menu Tools → Options → LibreOffice → View →
Font Lists
☐ Show preview of fonts (disabled).
That does work. Thank you LO no longer crashes when scrolling through the fonts. Though it cripples the preview feature. Therefor I implemented the solution I mentioned.
I also had to do this to prevent crashes. I just started using LibreOffice today and the version is 5.1.2.2
