sdk crash when a method called twice and too fast to creat a document
Hi , mi running a webservice that replace text in a docx template and then convet it to pdf.
Mi using ubuntu 18.04 and glassfish server for its deployment
when i made a single request for the service of converting everything is ok , but
when i made a double request too fast like a double clicking issue, i got this exception:
com.sun.star.lang.DisposedException
at com.sun.star.lib.uno.environments.remote.JobQueue.removeJob(JobQueue.java:201)
aused by: java.io.IOException: EOF reached - socket,host=localhost,port=8100,localHost=localhost,localPort=58494,peerHost=localhost,peerPort=8100
at com.sun.star.lib.uno.bridges.java_remote.XConnectionInputStream_Adapter.read(XConnectionInputStream_Adapter.java:50)
this is a portion of my code:
public Response getFilePdf(Integer idqueja) {
	try {
                // Initialise
   String oooExeFolder = "/opt/libreoffice6.1/program";
   XComponentContext xContext = BootstrapSocketConnector.bootstrap(oooExeFolder);
//XComponentContext xContext = Bootstrap.bootstrap();
XMultiComponentFactory xMCF = xContext.getServiceManager();
Object oDesktop = xMCF.createInstanceWithContext(
     "com.sun.star.frame.Desktop", xContext);
XDesktop xDesktop = (XDesktop) UnoRuntime.queryInterface(
     XDesktop.class, oDesktop);
// Load the Document
String workingDir = "/home/somePath/";
String myTemplate = workingDir + "template.docx";
if (!new File(myTemplate).canRead()) {
	throw new RuntimeException("Cannotix load template:" + new File(myTemplate));
XComponentLoader xCompLoader = (XComponentLoader) UnoRuntime
	.queryInterface(com.sun.star.frame.XComponentLoader.class, xDesktop);
String sUrl = "file:///" + myTemplate;
PropertyValue[] propertyValues = new PropertyValue[0];
propertyValues = new PropertyValue[1];
propertyValues[0] = new PropertyValue();
propertyValues[0].Name = "Hidden";
propertyValues[0].Value = new Boolean(true);
XComponent xComp = xCompLoader.loadComponentFromURL(
	sUrl, "_blank", 0, propertyValues);
// Manipulate
XReplaceDescriptor xReplaceDescr = null;
XReplaceable xReplaceable = null;
XTextDocument xTextDocument = (XTextDocument) UnoRuntime
		.queryInterface(XTextDocument.class, xComp);
xReplaceable = (XReplaceable) UnoRuntime
		.queryInterface(XReplaceable.class,
				xTextDocument);
xReplaceDescr = (XReplaceDescriptor) xReplaceable
		.createReplaceDescriptor();
    xReplaceDescr.setSearchString("<version>");
xReplaceDescr.setReplaceString("1.x");
xReplaceable.replaceAll(xReplaceDescr);
// mail merge the date
xReplaceDescr.setSearchString("<number>");
xReplaceDescr.setReplaceString("12345677");
    OOoOutputStream output= new OOoOutputStream();
// save as a PDF
XStorable xStorable = (XStorable) UnoRuntime
		.queryInterface(XStorable.class, xComp);
propertyValues = new PropertyValue[2];
// Setting the flag for overwriting
    propertyValues[1] = new PropertyValue();
propertyValues[0].Name = "OutputStream";
propertyValues[0].Value = output;
// Setting the filter name
propertyValues[1].Name = "FilterName";
propertyValues[1].Value = "writer_pdf_Export";
// Appending the favoured extension to the origin document name
//String myResult = workingDir + "fileConverted.pdf";
xStorable.storeToURL("private:stream", propertyValues);
// shutdown
xDesktop.terminate();
     ByteArrayInputStream inStream = new ByteArrayInputStream(output.toByteArray());
              ResponseBuilder response = Response.ok((Object) inStream);
                        response.header("Content-Disposition", "attachment;filename=queja.pdf");
                        return response.build();
	} catch (Exception e) {
		e.printStackTrace();
                    ResponseBuilder response = Response.serverError();
i build this guided by examples, i am a begginer in OO and LO , i saw the line of the exception was poiting to xDesktop.terminate(); , so i made an experiment and remove that statement , so now there is no raising of the exception , but as i mention i am a begginer so i am not sure what the xDesktop.terminate(); does and what is the consequences of removing it?
So this webservice method is planned to serve documents to a LOT of users, so if i got petition at the same time or too consecutive it will raise the exception unless i remove the xDesktop.terminate(); but i dont know if it will have further consequences like overriding the memory or things like that
