Version: 7.3.4.2 (x64) / LibreOffice Community
Build ID: 728fec16bd5f605073805c3c9e7c4212a0120dc5
CPU threads: 8; OS: Windows 10.0 Build 19045; UI render: Skia/Vulkan; VCL: win
Locale: en-GB (en_GB); UI: en-GB
Calc: CL
The purpose of the different sections in the book are to separate the different chapters, which are different parts of advice on how to pet sit.
I didn’t that one should/could set up page styles before creating the chapter via section breaks. So, I entered section breaks (next page) to put each chapter’s first page on the correct side. Where they would be on the wrong side, I have standard page breaks.
General layout and design.
The general layout of the design is the start of each chapter on the left in Libre to make them right in the book.
If this info helps, I used Ariel font. Sizes14 for the body text (justifide), 18 for the Chapter headings in the body (centred). 12 in the headers (centred). However, I removed the headers as I was not able to work out where the problem was when I was getting a chapter title carrying on into the following chapter.
There is a TOC.
P.S.
I just remembred that I was having trouble in Libre. It was either or both that
a) I didn’t know know how to export a document in Libre as a PDF.
b) I didn’t know how to do section breaks in Libre
So, I copied the document into Word.
I don’t recall if i already had the section breaks in at this stgae (Added in Liber). I reall don’t recall if I did the sectkion breaks in Libre or Word.
I have Word on my tiny 7 inch laptop,which I can only see to use if attached to external monitor to see what I am doing, Sadly, I can no longer get the laptop to see the monitor. So am back to Libre on my desktop with the desktop monitor.
At some point I trined to change ODT to Docx but I really don’t know if it changed in the first place or changed back!
Would all tis have messed up the section breaks so that I am getting previos chapter headings continuing in the next? I canot see the section break type to see if the inorect header in one is a Next or Continuos section break. When I correected the header that was continuing the previous heaser, then one ater the corrected one went wrong. So I deceided not to have headers in my book.
But after sulking, I decided I need to have them!
I am currently using Libre as I now know how to save as a PDF in libre.
