Setting keyboard shortcut keys for Writer breaks the ones set for Calc, and vice versa
Setting keyboard shortcut keys for Writer breaks the ones set for Calc, and vice versa.
When configuring the shortcuts, I make sure to specify it’s for only Writer and only Calc.
For example; I’ve now set F5 and Shift + F5 to Time and Date respectively, and now it doesn’t work in Calc.
I just want F5, and Shift + F5 to insert Time and Date in both Writer and Calc. Is there a way?
It doesn’t do that in 7.3.1.3 but it does in 24.2.1.2. Looks like a regression, please report a bug, How to Report Bugs in LibreOffice - The Document Foundation Wiki
Version: 24.2.1.2 (X86_64) / LibreOffice Community
Build ID: db4def46b0453cc22e2d0305797cf981b68ef5ac
CPU threads: 8; OS: Windows 10.0 Build 22631; UI render: Skia/Raster; VCL: win
Locale: en-NZ (en_NZ); UI: en-GB
Calc: CL threaded
In the interim if you don’t want to use the existing Calc shortcuts of Ctrl+Shift+; and Ctrl+; in Writer, it might be easiest to add the fields as AutoText entries, e.g. Time Fixed with shortcut tf (+F3)
