Hi, I’ve used and loved LibreOffice Calc for over a decade. Thank you all for this wonderful piece of software, and for the community!
I frequently have to work on survey data from field surveys. Our surveyors enter the data into Google Forms, which I then export to a CSV file and work on in LO Calc. To do this I have to create pivot tables - often up to two or three dozen for a single survey.
But I haven’t been able to find a way to speed up creating these tables. At present, for each table I create, I have to manually:
- Drag the appropriate column name into the row fields with a mouse
- Drag the appropriate column name into the data fields with a mouse (this is almost always the same as the row name)
- Double click on the data fields to pull up the “Data Field” dialog
- Manually set this to “Count” instead of “Sum” (given the way our survey data is formatted)
- Manually choose the drop down option under “Displayed Value” for “% of column”
Given the number of tables I have to make, this adds up to a lot of repetitive work and time that seems unnecessary. In my ideal world I’d be able to set a ‘template’ for a pivot table, then tell LO Calc to generate multiple pivot tables for each of a set of columns that I give it. But if that isn’t possible (I presume that would require scripting), is there a way I can set a template for the Data Field settings at least? That would save steps 4 and 5.
Thanks in advance!
