If I change line widths or Area fill to ‘none’ , then if I close and re-open the drawing the settings have reverted to the ‘default’ values. I want to keep these settings for the entire drawing but they are changed to default every time. Or am I doing something wrong ?
Please delete your answer as it is not a solution to your initial question. Edit your question or write a comment if necessary. Thank you.
Requirements can be entered on Bugzilla.
Yes that is unfortunately so.
In an answer here on AskLibreOffice (i can’t find it right now), it is recommended to save objects in the Gallery with your desired formatting.
From there you can insert them again if necessary.
Maybe it will help you.
