Everything appears to work fine during editing and save of a Writer document. But on reloading (File > Reload), several shapes used in diagram frames have ‘disappeared’. After some experimentation I’ve established:
(Using LO 4.4.0.3 in Win7)
DRAW shapes all appear ok when first copied into a WRITER frame.
Certain DRAW shapes (circle, rectangle etc) are missing from the frame after re-loading the WRITER document. Note DRAW lines and text boxes are unaffected.
Using “Arrange > Bring To Front” has no affect.
A single DRAW shape e.g. circle copied to a frame OR to page, PERMANENTLY disappears after reload.
Two or more shapes copied over (as a group) do re-appear after reload but are ALWAYS behind any frame area fill, hence only visible if transparency >~10%
Anyone else experienced this issue?
