Since a few weeks Shrink To Fit Cell Size does not work (cell 2 in the image)
If I use Clear Direct Formatting, the text, while maintaining the same Font Size, is reduced to an almost illegible size aligned at the bottom left (cell 3 of the image)
Furthermore, the text in cell 2 is not visible in the print preview.
Some idea?
I created a new file. It seems all ok but in print celle 3 is again reduced to an almost illegible size aligned at the bottom left
Untitled 1.ods (10.4 KB)
