Slow work with shares mounted by pam_mount
Libre Office (Tried different versions) very slowly opens documents located on a network share mounted with pam_mount utlity. In case if i mount the same resource using “mount-t cifs” command then documents open quickly.
The problem is observed only with libre office, other editors open documents quickly.
I’m use Debian-based distro. How to understand what the problem is?
Collected work logs using libreoffice7.0 --strace. Throughout the “freezing” of the libre office in the logs, messages like:
4130 12:58:55.413241 close(92) = -1 EBADF (Bad file descriptor)
4130 12:58:55.413282 close(93) = -1 EBADF (Bad file descriptor)
4130 12:58:55.413323 close(94) = -1 EBADF (Bad file descriptor)
4130 12:58:55.413364 close(95) = -1 EBADF (Bad file descriptor)
4130 12:58:55.413405 close(96) = -1 EBADF (Bad file descriptor)
4130 12:58:55.413446 close(97) = -1 EBADF (Bad file descriptor)
4130 12:58:55.413487 close(98) = -1 EBADF (Bad file descriptor)
4130 12:58:55.413528 close(99) = -1 EBADF (Bad file descriptor)
4130 12:58:55.413569 close(100) = -1 EBADF (Bad file descriptor)
4130 12:58:55.413609 close(101) = -1 EBADF (Bad file descriptor)
4130 12:58:55.413651 close(102) = -1 EBADF (Bad file descriptor)
And so on for a minute
The following mount options solve this problem:
options=“user=%(USER),cruid=%(USERUID),dir_mode=0770,file_mode=0770,rw,iocharset=utf8,noperm,soft,nouser_xattr,vers=1.0”
“vers=1.0” pframeter needed only for Windows Server 2003 shares.
