Can anyone solve this problem?
After downloading the latest Eurocontrol Small Emittors calculator from Small emitters tool (SET) | EUROCONTROL and then then opening it with Calc it gives 504 error.
Older versions worked fine.
Wen asked for an OpenSource tool, the answer by Eurocontrol was:
“Unfortunately we are not validating (nor currently supporting) the tool under openOffice or under non Microsoft Excel tools*
One way out would be to ask the actual equation which are behind the SET, and build a version under LibreOffice or another tool.
The equation can be requested and obtained after signing a specific agreement.
I attach a draft agreement for information.
*Should you want to proceed in that way, please fill the below information and send-us an email back at ets.info@eurocontrol.int”
thanks for help.
