Hey everyone. I’m trying to learn how to use LibreOffice a bit better, and also need some coding for something I’m working on.
Basically what I’m hoping for is a…
If a cell in Column A has X in it, then insert “text” with the value of the information in the cell of Column B and C that is in the SAME ROW at specified points…
An example may help:
Right now, it looks like |TBA |2 |4 |
With TBA in column A, 2 in B, and 4 and C.
I want a formula that will see that Column A has TBA, and change it to : Tap Break-in Active from 2 to 4 o’clock.
The value of column B and C changes with every row, so it should only apply to the cell that’s in the same row.
If this doesn’t make sense, I’ll explain more.
