Split Database and copy other than tables/forms etc
I am attempting to split a database and have used the wizard method followed by copying in all tables/forms/reports and macros from old one. Is there a way in copying over other things such as relationships and macros?
If I recall correctly, you must re-establish relationships. As for macros, you are most likely referring to embedded macros. Copy and paste is the safest method.
Thought just as much. Thanks
