Using LibreOffice java sdk 7.4.7 on Mac OS with LibreOffice version 7.4.7.2. Connecting remotely and loading spreadsheet with existing data (works).
I want to programmatically (using java sdk) create and run Standard filter using operator Contains with value being regex to filter data based on it (this works perfectly with a manually created Standard filter). The issues I am facing:
- TableFilterField.Operator field is FilterOperator enum which doesn’t include Contains operator. Therefore, I can’t use TableFilterField when specifying filterFields on XSheetFilterDescriptor used for filtering.
- Found XSheetFilterDescriptor2 with TableFilterField2 where TableFilterField2 has Operator being long which is great since Contains operator can be set to it. So I tried below
XSheetFilterable xFilter = UnoRuntime.queryInterface(XSheetFilterable.class, cellRange);
XSheetFilterDescriptor2 xFilterDesc2 = UnoRuntime.queryInterface(XSheetFilterDescriptor2.class,
// This returns SheetFilterDescriptor which also implements XSheetFilterDescriptor2
xFilter.createFilterDescriptor(true));
TableFilterField2[] aFilterFields = new TableFilterField2[1];
aFilterFields[0] = new TableFilterField2();
aFilterFields[0].Field = 12; // 13th column
aFilterFields[0].IsNumeric = false; // Not-numeric means text
aFilterFields[0].Operator = FilterOperator2.CONTAINS;
aFilterFields[0].StringValue = "foo|bar";
xFilterDesc2.setFilterFields2(aFilterFields);
but XSheetFilterable.filter(XSheetFilterDescriptor xDescriptor) method accepts XSheetFilterDescriptor as its parameter NOT XSheetFilterDescriptor2 which I’ve constructed above, so I can’t use it for filtering, below won’t compile
xFilter.filter(xFilterDesc2);
Is there a way to make filtering work using XSheetFilterDescriptor2 ?
3. I also tried to do this filtering via Advanced Filter style below, which also doesn’t work because xFilterDesc is always null below
XCellRange xCritRange = xSpreadsheet.getCellRangeByName( "N1:N2" );
XCellRangeData xCritData = UnoRuntime.queryInterface(XCellRangeData.class, xCritRange);
Object[][] aCritValues =
{ "Name" },
{ "Contains foo|bar" } // trying to use Contains operator
xCritData.setDataArray( aCritValues );
XSheetFilterableEx xCriteria = UnoRuntime.queryInterface(XSheetFilterableEx.class, xCritRange);
XSheetFilterDescriptor xFilterDesc = xCriteria.createFilterDescriptorByObject(xFilter);
if (xFilterDesc != null) {
log.info("About to use xFilterDesc {}", xFilterDesc);
xFilter.filter(xFilterDesc);
else {
//I always get in here so can't use this method
log.error("xFilterDesc was NULL");
Is there a way to make this work ?
