Sub procedure or function procedure Increment already defined problem
Hi
I have some code that I use for a small project I work on. I’m receiving the following error:
“BASIC syntax error
Sub procedure or function procedure Increment already defined”
on this line: Function Increment(v As Variant)
Can anyone spot where the problem is and how to fix it?
Thanks so much.
Sub Move1Range(sRangeAddress As String)
Dim oActiveSheet As Variant
Dim oCellRangeByName As Variant
Dim oDataArray As Variant, tmp As Variant
Dim i As Long, j As Integer
        oActiveSheet = ThisComponent.getCurrentController().getActiveSheet()
        oCellRangeByName = oActiveSheet.getCellRangeByName(sRangeAddress)
        oDataArray = oCellRangeByName.getDataArray()
        tmp = oDataArray(UBound(oDataArray))(0)
        For i = UBound(oDataArray) To LBound(oDataArray)+1 Step -1
                If Trim(oDataArray(i-1)(0))="" Then
                        oDataArray(i)(0) = ""
                Else
                        oDataArray(i)(0) = Increment(oDataArray(i-1)(0))
                EndIf
        Next i
        For i = LBound(oDataArray) To UBound(oDataArray)
                For j = 1 To 3
                        oDataArray(i)(j) = ""
                Next j
        Next i
        oDataArray(0)(0) = Increment(tmp)
        oCellRangeByName.setDataArray(oDataArray)
Function Increment(v As Variant)					‘ (problem here)
Dim rv As Variant, arr As Variant
    rv = v
    arr = Split(v, "-")
    If UBound(arr) = 1 Then rv = arr(0) & "-" & CLng(arr(1)) + 1
    Increment = rv
End Function
An error message concerning “already defined” is not plausible if there aren’t additional code lines not posted here.
The only syntactical error actually occurring in the posted code is the bad (“typographical”) apostrophe behind the header of the function declaration.
That removed, the code doesn’t something obviously reasonable, but runs without problems.
BTW: What do you try to achieve with that code?
Hi Lupp
Thanks for you’re reply. I spent some more time and found the conflict and it now works. Thanks again.
