Tabbed Menu tabs when using themes
When using a “Preinstalled Theme (Dark)” with tabbed menu bar has turned the font in the menu tabs to white…very hard to see and use. How can I change the color of the font in the menu tabs. Also, the menu ribbon does not take on a “Dark” theme…stays as default white (background) with black (font). Thank you for any help…much appreciated. Best Regards, Dean
